How can setup Skype software?
Skype setup : It's very easy way
1. At first download or open Skype software.
2. double click to the setup icon.
3. Select your language then click I agree – install.
4. Click Continue installing Skype.
5. If installation completed then if your not Skype ID so, please select
don't have a Id then type Your Full name, create Skype Name, Password and
Repeat Password then field mark if you agree then Click Next.
6. Type your email address
7. Select country/Region and City
8. Click Sign in and get started now.
Setting up Skype on your computer consists of 3 basic steps. First, install Skype on your computer; second, configure your computer to use Skype; then third, make a call to the Skype Call Testing Service to make sure everything is working.
The first thing to do is to download Skype to your computer.
To download Skype, visit skype | Get Skype and then download the installer.
After installing Skype configure it and then install other devices you need to use with it like the webcam.
You should also configure your computer’s microphone to make sure it is working and to adjust its volume as well.
And the most important part is your Skype ID and password.
If you don’t have an ID yet you need to create an account first to get your ID and password.
FIRSTLY YOU WILL DOWNLOAD SKYPE SOFTWARE BY SIGNUP PROCEESING. THEN OPEN IT & CLICK RUN.AFTER FEW TIMES AUTOMATICALLY,IT WILL BE INSTALLED.
WHEN INSTALL PROCESSING IS COMPLETED,SIGNIN PAGE IS OPEN.
THEN INPUT IN YOUR USER NAME & PASSWORD.
CLICK ON SIGNIN BUTTON. SKYPE SOFT IS WORKING CORRECTLY.
Notifications
