How can sharing PC screen on Samsung TV?
If you are using Samsung TV, and watching TV shows on limited PC screen, Its the tactic for sharing PC screen on Samsung TV.
Hello Daimz_steph,
Off course you can share your pc screen on Samsung TV.
There some steps to be follow to share your screen on Samsung TV those are follows
1. Unplug your vga cable from pc.
2. Connect your vga back to back cable to your pc and Samsung TV.
3. Than share screen will be automated.
By doing the above steps you can solve your problem.
Thanks
Hello Daimz_steph,
It is definitely possible to stream your TV shows from your PC to your Samsung TV. All you needed is to have an HDMI cable which are available in computer or appliance stores. HDMI allows both the audio and the video to be transferred from your PC to your TV in just one cable.
Another option is to record the TV shows in a USB stick. Then you can plug it in your Samsung TV so you can view it on a wider and larger screen.
Enjoy!
You will have to get HDMI screen which will show your display on to your LED or LCD TV, but before it you need to make sure that your LCD or LED supporting HDMI cable and can share so you can share your screen.
