How can I speed up DSL connection type internet
Asked By 130 points N/A Posted on -
I am currently using DSL connection with upload and download speed of 1 Mbps. Since, I am required to open large sum of data's and files for my job, I need to increase the speed of my DSL. Is there a way or any third-party software that I can use and will help me boost my connection? How can I speed up my DSL internet connection?
Best Answer by Caliso Balkar
Answered By 0 points N/A #124269
Hi Hekmat,
This guide below will surely boost your internet connection. I've been using this guide since.
1. Click start on your computer or simply press the window key on your keyboard.
2. Click run and type in this word devmgmt.msc and press enter and if your using windows 7/vista click start and type this word on the search box devmgmt.msc and hit enter. The device manager window will then appear.
3. Now look for the word port and double click it. You will see a Communication Port properties.
4. Go to the Port Setting and now increase your "Bits per second" to 128000 and "Flow control" change to Hardware.
5. Click apply. Then see the big difference.
Also clear your browsing data, cache and history in your browser.
Happy browsing.
Answered By 5 points N/A #124270
There are lots of ways to increase the speed. there are many software which used for this purpose. So you should download such software and your speed will increase. If you are using 1 MB connection then you speed of downloading speed is fine. But if your connection is more then 2 MB then you need to ask your internet provider to setup your line connection.
You can search out the software from the GOOGLE easily and download it.
Answered By 10 points N/A #124271
You can speed up your network speed in many ways. You can use softwares for downloading and you can get a better service to enhance your network speed. If you want to increase the speed for download then you can install and purchase IDM and it will enhance your download speed automatically when you are downloading using this program. There are also many other programs that can help in this regard you can choose one as per you require.
Also make sure that all program updates are disable so that you can get full speed to while using the net. Check all program settings and make sure that they all are disabled by automatic up dates. Once you have done this you will be able to enhance your network speed.
Michal joran.
Answered By 0 points N/A #124272
Hello Hekmat,
Side by side these solutions you can watch a Techyv YouTube video tutorial according to your question to get practical idea.
Speed Up Internet Downloads With Internet Download Manager
