arefin.tec
20 points
Posted on - 08/07/2011
I'm asfakul arefin from Bangladesh. My os is Ubuntu 10.04. i ask a question about Ubuntu Linux. My question is "How can i get new version Ubuntu 11.04 in my computer. I do not want to newly setup but want to upgrade my old system. If it's possible please solution me.
Thanks
How can upgrade ubuntu 10.04 to 11.04.
It is possible to upgrade 10.04 to 11.04 without having to reformat your old system.
https://help.ubuntu.com/community/UpgradeNotes
However, as you will see from the above link, Ubuntu only supports upgrading from 10.10 to 11.04 and upgrading from 10.04 to 11.04. Therefore, to upgrade 10,04 to 11.04, you will have to first upgrade your 10.04 to 10.10 before you can upgrade your 10.10 to 11.04.
Before proceeding with the upgrades, you should first ensure that all updates for your current version have already been installed.
Kindly check the link I provided since it already contains all the information you will need.
Good luck on your upgrade and post back to let us know how it turned out.
