How can use I more display in any computer?
To use multiple display or projector is not a critical job. Now in a day all most every computer has the facilities to use more display or projector. If you have not the facilities, you have needed to install the multiple video cards that support the multiple displays.
After install the multiple video card you have need to select the dual view mode in Microsoft windows. You can use the following steps. Start—Settings—control panel– then double click to the display icon—click properties then click settings then click the down arrow and select the secondary display. Now your computer is ready for viewing multiple displays.
If you want to connect another monitor on your computer and setup a dual display, the easiest way to do it is with a USB to VGA video adapter like this one on eBay: Startech.com USB32VGAPRO USB 3.0 to VGA Video Adapter. It ships with 512 MB video RAM and supports the following connectors: VGA, USB 3.0, USB 2.0, D-Sub, DisplayPort, USB-C, and HDMI.
This item is used for $57.99 plus $28.11 additional cost and located in Santee, California. If you want brand new, try this one: Startech.com USB32VGAPRO USB 3.0 to VGA Video Adapter. This item is brand new for $65.99 plus $5 shipping. Item is located in CT, Austria.
