Reddy
Posted on - 10/18/2013
Hi All,
How can we delete multiple mails from iPHONE 5.
I have a account that's spammed totally and need to delete all emails
Another account that needs few deleted daily.
I know this can be easier on a desktop/laptop but whats the way from an iPHONE 5 iOS 7.0
We did have a easier way in the older versions of iOS
How can we delete multiple mails from iPHONE5
Hi Reddy
Yes you can delete all your emails in iPhone 5 simply follow this steps.
Go inside your mail client, click on the upper side Edit, then just select the first mail, while pressing down the move button, do not take of your finger just keep pressing down, then deselect the selected mail while your finger is pressing down the move button. Then release, a message will show, if you want to delete all items then click trash. Now the mails are gone.
