How can we find which DC is being authenticated?
How can we find which DC is being authenticated? For the desktop i am in. What is the commands to find that?
Thank you.
Thank you.
If this is the first time you’ll be using and or installing the program, you should check first its system requirements so you will know the necessary technical information.
After checking this part of the program, you should check next if your computer meets the necessary requirements and if it lacks something from the list, like for example it requires installing of Adobe Flash Player and Microsoft .NET Framework and you don’t have these yet on your machine, then in this case you should download and install them first before installing the software.
There are also instances where your installation encounters unexpected error which is very rare to happen. If this happens just try restarting your computer then restart the installation.
