How can we identify the real capacity micro sd card?
40 points
Posted on - 09/25/2011
I have been using a 4 GB Macro SD card in my cell phone, where I can store about 3.5 GB data. From where I am able to use about 120 MB space of video and audio files. I came to know that there are two types of Macro SD.
One is upgraded macro SD (Which normally upgrades from lower capacity of memory chips). Another one is Real capacity Macro SD (it makes from same size or capacity of memory chips).
Could you tell me what is the best way to identify the Real capacity and upgraded Macro SD.
