b_chawdhury
Posted on - 01/19/2013
There is a best way to make converting 3ds to nds. Autodesk 3ds Max can provide a comprehensive, integrated 3D modeling animation. It's the best way to convert 3ds to nds. Autodesk 3ds Max provides a comprehensive, integrated 3D modeling, animation, and rendering solution for game developers, visual effects artists, and graphic designers. By this software, we can convert 3ds to nds.
How can we make Converting 3ds to nds?
Hello B Chawdhury,
You can convert your file from 3DS to NDS. I think there are some sites where you can download convert software for free. You can use the 3DS Video Converter or R4 3DS Emulator to convert. You can also get those files for free. I hope both of these will work perfectly.
Max
Hellow B Chowdhury!
Your interest is very clear to me.I am giving a effective suggestion for a great solution.
You can use the Quest NDS Migrator. It can update the resources automatically. It incorporates all windows capabilities. It can play in the graphical user interface.
The second recommendation for you is to use the NDS Explorer. NDS Explorer exhibits the NDS-Game Image as Icon and Game –info as popup menu.
Regards
Shifflett Laurel
