How can we moderate comments in blogger?
I always get comments from other suspicious blogger that leaves link in my comment. In order to prevent this spamming activity I want to monitor my comments feature. What I want is to make an approval from me before someone can see his/her comment to my post. How can I do that?
Best Answer by smithgood
Answered By 0 points N/A #157755
This is an interesting question and also you can say it that it is a big problem which is we are facing in our society. To overcome it you have some choices without options. So there is one thing with the native bloggers blog you can comment moderately mean you can published to blog spot or externally is quietly simple. In some choices you have one of them like you can choose moderately comment before the publishing.
Also you can perform like this laterally by doing after the comment is published. So it is very clear that you can do like both of them either by allowing it or by rejecting it. I suggest you that you have these options better as compare to it like "trying to block commenters or visitors".
By some settings you can enable or disable the comment moderation. In these settings you have something like this: You must be  consider that show or hide comments, block comments, placement of comments, comment notification e-mail, and comment moderation. you just do one thing for it go to the comments link of any post to reach to the published comments for that post. For more details please visit this site.
Answered By points N/A #157756
Blogging is a great way to spread one’s thought. At the same time, it is also a nice way to spread vulnerability. In order to prevent comments to be posted on blog, you can moderate it before it is published.
Here are the ways that you can moderate your blog’s comments before publishing in Blogger.
1. Go to https://www.blogger.com/about/?r=1-null_user. Login into your account.
2. From your blog’s left side, go to “Settings”.
3. From the left panel, go to “Posts and comments”.
From here, you can easily moderate your comments; whether they will be directly published or not.
In order to check waiting comments,
1. From the "Settings", go to Comments >> Awaiting moderation.
Cheers!
