How can web user control Google maps in ASPNet?
I have aspx pages and I want to insert Google map. Does anyone have a user control for ASP.Net. Is it possible to add kmz/kml layer to Google map for ASPNet user control?
It is possible to insert Google maps in aspx pages. There are some apps which you can directly code into the webpage and there are some software in which you have to create the code to insert Google maps in aspx pages.
One solution is to go to https://developers.google.com/maps/ and download the setup file. Install it on your computer and run it. Using this app you can insert Google maps directly into your webpage.
Another solution is to go to http://googlemap.codeplex.com/ and download the software. Install it on your computer and you can insert maps in your aspx page.
Hope this information helps you.
There are several differences between those two controls. Some of them are listed below:
