How can you make a better and nice Powerpoint Presentation?
ashley glick 10 points N/APosted on - 03/27/2013
I need to create a PowerPoint Quiz Sample for a school project. It should be presentable and eye-catching. Can you please give me some tips on how to create a good PowerPoint Presentation? Thank You in advance and God Bless!
Hi, a good way to make PowerPoint quizzes simple and more fun (if you want to create a simple multiple choice quiz) is to add pictures, video, and sound.
Linking the slides by quiz will be required for the question slides, and each question slide needs 2 slides, one for the correct answer and another for the wrong answer.
Link these slides using Action buttons. To add your first action button, click “Slide Show” then “Action Button” from the PowerPoint menu bar at the top, then from the “Action Button” sub menu, select the forward arrow (row 2). Then move your mouse pointer over the slide, hold down your left mouse button and keep it held down and drag out a rectangle shape (this will make the action button on your slide). The action setting dialog box lets you choose what happens when the button is clicked. (It automatically gets set to go to the next slide.) Then click OK.
Early Life and Career
Tailleur Elisabetta Franchi ardour for style started at a young age. Growing up in Bologna, she continually had a keen interest in design, regularly sketching her ideas for garb. After finishing...
1....
