How can you upload i576 ringtones?
How can you upload i576 ringtones and assign a ringtone to a contact? For Motorola i576.
Thank you in advance.
You can upload different kinds of ringtones or true tones on your Motorola phone if this is supported by your device. And you can only do this if your phone has a software installed on your computer or maybe if your device is capable of using Bluetooth connectivity where you can receive the ringtones and then save it on the memory card of your phone.
If these things are supported by your mobile phone then it is possible to assign a ringtone to your contacts list. But that is if this is also supported by your device. But if not then you just have to stick to its default ringtones and sounds.
If you have Motorola i576, download and install the Motorola PC Suite. It will help you easily connect and access your phone through your computer using the USB cable or via Bluetooth.
It lets you synchronize the contacts on your phone with Microsoft Office Outlook; send text messages directly from your laptop or desktop computer; and create custom ringtones, MMS slide shows, and wallpapers and transfer them to your handset. To connect your phone to your desktop computer via Bluetooth, your machine should have a Bluetooth receiver or Bluetooth adapter which laptops normally have.
To assign a ringtone to your contacts, press or go to Ring Tones. Scroll down through the list and select the ringtone you like. After selecting one, press OK or press Assign using the left softkey. Next, select A Contact. Highlight the contacts entry you wish to assign the ringtone to and then press OK.
