How can I capture ip black berry devices via wifi? Is it possible to get the IP of the wifi connection using my blackberry or an app for it? If so, please do tell what application or the steps how to do it! Thank you
How to capture ip black berry via wifi
Dear user,
Follow these steps, they might help you:
1) Open the TCP server on you blackberry through Wi-fi and look for its IP address.
2) If it doesn't work, then get the APN id for the MagicRudyAPN.rim using getAccessPointerNumber and see for it's IP address using getIPAddress.
Hope this will work for you.
Thank you.
Hi. If you want to know the IP address from which your BlackBerry device is connected, just follow the steps below:
1. Click Options.
2. Search for the Advanced System Settings.
3. Click the Host Routing Table.
4. Select the one that is written in Bold letters. This is the one from where you can find your IP.
5. Click it and there you can scroll down to IP/Ports. The IP is written under the IP/Ports.
For other way to know your IP address, just go to https://www.whatismyip.com/ using your BlackBerry device. Your IP will be automatically shown on the screen once you visit this website.
