I want to know how to capture Octoshape stream. I enjoyed live streams on some sites and they have moved to Octoshape plugin. So I can not capture the HD stream. Is there any solution? Please help me.
How to capture Octoshape stream directly from browser?
Hello, Arther
Hope you are fine. Don’t worry. I think I can give you a solution.
If you want to capture Octoshape stream , you will need to capture screen. Download the capture screen and try.
Click here
You can also record Octoshape stream with VLC player. For this you will need HTTP to be figured out. However follow the steps below
At first install windows Octoshape plugin from http://www.octoshape.com/files/octosetup.exe
Go to VLC Tool –
Preferences
Interface
Set up associations, select all file types.
Then in Octoshape Settings , for setting , just right click on the Octoshape system tray icon and then select Settings.
Select"System player"
Now Create a bat file namely stream.bat.
In the bat file type "C:Documents and Settings[user]ApplicationdataOctoshapeOctoshape Streaming ServicesOctoshapeClient.exe" -url: [octostream] for windows xp
Type "C:Users[user]AppDataRoamingOctoshapeOctoshape Streaming ServicesOctoshapeClient.exe" -url: [octostream] for windows vista 7
Now with your current user name has to be replaced by the name of the Octoshape stream.
On double clicking on stream.bat, the VLC player should be started.
Press the play button to play.
Hope you will get your answer.
