Emaily Rawa
10 points
Posted on - 11/18/2012
Hi techyv,
How to change apple videos font? I am using ios in my apple desktop and was thinking for a software that is compatible with ios to edit video fonts. I would like to change some subtitle of my video. I got a mp4 file format.
Hoping for your help. Thanks.
You can download “Apple Font Tool Suite.” It is a command line of tools for working with font files. This single installer package is equipped with a 60 page Tutorial, User documentation, and a Quick Reference guide.
You can download it here:
https://developer.apple.com/fonts/
There are also other applications for your fonts available in that website, such as “True Type Font Format Specification,” and “Unicode Fonts.”
Hi Emaily,
There are various options with help of which you can edit our apple videos font. A good resource is Final Cut Pro which is advanced editing software for Mac.
Below link would take you there for downloading.
https://filmora.wondershare.com/get-creative/
It will help you edit not only font, color, but also with stylish titling.
Hope this helps.
Thanks
Baker
