How to change background in video call?
I am using Skype video call, and I don’t have any background theme for each other’s video.
Is there a way to install a theme for video calling background for Skype?
If there is some possible solution I hope you can inform me as soon as possible.
Waiting for your support, thank you.
Best Answer by Parthy Goan
Answered By 0 points N/A #180311
Hello Wendy,
There is some possible solution for you. You could not change the background in video call except your webcam have built-in that feature. May be the following information will be of some help.
I think it will help you a lot.
If you can change your background you does not need to change themes.
Thank you.
Answered By 0 points N/A #180312
Hello Anthony Wandy,
Unfortunately, there is no option available for changing the background of video call in Skype.
You could not change it unless your webcam have this feature built-in. Visit this site  to get help for the webcam theme change feature.
You can download AV Webcam Morpher and then you will be able to do this.
Answered By 590495 points N/A #299389
If you are using Skype and you want to change the background theme, unfortunately, that’s not possible. Skype itself doesn’t provide an option to change this setting. If you want a webcam software that will allow you to change the background theme or that will change whatever your background is, try using ManyCam. Visit Download ManyCam Free Webcam Effects and download the free version.
For Microsoft Windows, it supports Windows 7, Windows 8.x, and Windows 10. It requires Intel Core i3 or faster processor and 2 GB RAM. Windows XP and Windows Vista are no longer supported. For OS X, it supports OS X 10.9 Mavericks and higher. ManyCam allows you to change the background and apply webcam effects and graphics. You can also add texts to your webcam feed.
