How to change cm9 show date status ?
Hi Experts,
I want to change cm9 show date status.Currently this status is being disabled.I seek expert advice to enable this.I tried to change this setting by its control panel.But could not find the exact place to achieve this.Thanks.
Orlaandoaddison
Answered By 10 points N/A #131358
To change cm9 show date status you need to install acme installer. Since you have cm9 I suggest you install acme installer 2.
After you have the acme installer 2, follow the steps below:
1.    Connect your device to the wifi connection of your choice.
2.    Then go to the area where time should be displayed and drag it down. This should open the settings tab.
3.    Search for time and date option and select it.
4.    Set the time and date and click ok.
5.    You will be asked whether you want to set it automatically. Click ok.
6.    Scroll down to find an option – Show time and date. Click ok.
This should solve your problem.
