How to change the created date of a PDF?
Hello experts,
How to change the created date of a pdf? I got an email from a business partner and I was asked to do some date editing with almost 50 pdf files. However, I don’t have any idea on how to edit the date of a pdf form. I just want to ask you regarding this matter, your answer will be a big help. Thank you.
Best Answer by Fermin Marie
Answered By 0 points N/A #181306
There are many methods to edit PDF documents, but the need is to have spam free software from a free website. So, here’s a method to solve that problem.
1. First download and then install the Advanced PDF tools from the link under here:
2. Run the software in your computer and then add your PDF file in the software. Check that the file entered successfully.
3. Find the words ‘Create Data’ in a column and mark the box.
4. Then write the date in editable region.
5. Next press the button marked ‘Change’.
6. The date will be changed and you can see it by opening the properties of a file.
This will lead to changing the date of a PDF file. Hope this will help a lot.
Answered By 0 points N/A #181308
You can use Adobe PDF editor tool. This adobe acrobat tool allows you to edit texts among other things. With a case as yours just select the text to be edited and choose the change date option from the editing panel tools. Other available tools include changing text font size, styles, replacing words among others.
