How to change the default cursor in smf forum?
Does anyone know a code I should use for my smf forum to modify the cursor? I need to change my cursor, the default one, for example it should change on mouse hover too.
Hi Petarpfc,
If you want to change the cursor on smf forum, first you need to add/ change some code.
Here comes the code for changing the cursor on any web-page
Cursor: auto
Cursor: crosshair
Cursor: default
Cursor: e
Cursor: help
Cursor: move
Cursor: n
Cursor: ne
Cursor: Nw
Cursor: pointer
Cursor: progress
Cursor: s
Cursor: se
Cursor: SW
Cursor: text
Cursor: w
Cursor: wait
Each line of code will change the cursor.
You can add this code in the style- sheet but if you are not using style-sheet you can add this code in the head section of the source code.
<Style type="text/css">
Cursor : "what ever from the list above";
</Style>
But if you want change the cursor when someone just move the mouse over the link (hover) the code will be:
A: hover
Cursor: "what ever from the list above";
</Style>
You can put this code in smf forum follow it:
_ Open the css file and locate this comment "/* Normal, standard links. */"
_ Find "a:hover" & then add cursor: "What ever from the list above";
_save the css file & upload it to the server to see the change on the live smf forum.
_Change the cursor on blog spot {your blog} then log into your blogger account >> go to layout >> go to edit html>> search for
hover >> you find 2 result > the first result add>>
Finally I hope that I know help you.
Notifications
