How to change the default font in Microsoft works 8.5?
Hi!
I am using Microsoft Works 8.5 to create labels and I get a problem when I try to change the default font type.
If I try to make the change after I typed the label, the font changes back to the default.
Does anyone have a solution?
Answered By 0 points N/A #105258
Hi Harvey,
To change the default font type in word this are the steps that will lead you to successfully doing so:
If you do not have an open document then create one in normal template. On the format menu click font then click the font size and any attributes you want from here. Click default, when you receive the message that states 'do you want to change the default font to font name'  click yes. Word will not prompt you to save the changes unless you click save from the save tab and if by chance it does then click cancel. This steps are straight forward and I hope you will be able to do your change in a very easy way.
