How to change default page in browser?
Is there anyway to change the default page which appears on my page to any other page.
I would like it to change it to Facebook.
Any help would be appreciated.Thanks.
Hey Joey Fergus!I
t is very easy to set some random web page as your home page. As you have not mentioned above that which browser you are using so I am going to tell you the procedure to change home page for Internet Explorer, Opera, and Firefox.
For Internet Explorer:
Open IE and click on the Tools Button on the upper toolbar of the browser.
Select "Internet Option" from the list. It will open the internet options.
In the General Tab, write down the website address (www.facebook.com in your case) in Home Page section.
After that click on the "Use current" button and press ok. You are done.
For Mozilla Firefox:
Open Firefox and click on the Tools Button on the upper toolbar of the browser.
Select "Options" from the list.
In General Tab, under Startup section, write www.facebook.com in Home page and press "Use Current" button.
Click on Ok button. And you are done.
For Opera:
Open Opera and click on the Tools Button on the upper toolbar of the browser.
Select "Preference" from the list.
In General Tab, write www.facebook.com in Home page and press "Use Current" button.
Thanks
For Internet do following:
Go to Tools, select Internet Options
On General TAB, enter following "www.facebook.com" then pres use default.
Click OK .
For Firefox
Go to Firefox tab, select Options.
On General TAB, enter following "www.facebook.com" then press “use Current Page”
Click Ok to Save.
Notifications
