How to change font size in Evo 3d?
The font size in my  Evo 3d is small. I like a larger font size for my emails (inward and outward)and for my messages. Please tell me how to change the font size in Evo 3d.
Thanks
Best Answer by Alexander Dubson
Answered By 0 points N/A #134838
You can change the font size of your Evo 3D completing these steps
1.Go to Messages And Enter in Menu
2.Go to "More Options"
3.Now Scroll Down little bit ,
there you will see an option to increase the font ,you will see six different options to change the font of your Evo 3D.
Answered By 0 points N/A #197899
Font size can often be a hassle when dealing with emails in some Smartphone devices. If your current device uses AOSP, one of the best ways to fix the problem is to manually download from your phone the font you want to use. Considering there are databases with several different fonts, it is quite straightforward to get one that suits you and your preferences.
Here are a couple of examples of links you could follow:
Font Installer for Android.
Font Squirrel, collection of fonts.
