Hi everyone. MS PowerPoint is an excellent tool for businessman, educators, students or whatever to brief discussion, presentation. While editing some free ppt designs download it does not save changes what I made. I have added some animated pictures it by using MS Office 2010 and when I use slide show, those pictures are not displayed. I am wondering what is happening. Have you any suggestion please?
How to change free ppt designs download while having Office 2010?
Power Point is a package provided by Microsoft. If you do not have sufficient permission or license for the product, then it will not allow you to change the document. Secondly, in MS Office 2010, if you wish to insert some pictures, then you need to first check the compatibility for those pictures. If the supportive format for the pictures is not used, then it will not display the picture on the MS Office file.
Hi Theresajmickens,
You have to be very careful to the PowerPoint presentation template you are downloading.
There might be a problem with the version compatibility.
Did you try to open the downloaded templates in another PC where is running an older PowerPoint version?Â
Do you still have this problem?Â
I suggest to download templates compatible with MS Office 2010.
