How to change Gmail account on phone
Should I do a factory reset if I want to change my Gmail account on my phone? I was advised that you can go to: setting, apps, Google apps, turn off and clear defaults, then go to market and it will ask for account and sign in with new account. Well with my ROM or any ROM or rooted device this does not exist. No option.
But what is the easiest way to get my apps back. I did back up in Astro. Should I go to each .apk file in the backup folder and hit "install"?
Thanks so much for your help in advance
