Hi Experts,
I am having mac os on my pc.I want to change the profile image msn 8 mac to some other image.I am asking will it affect my mac os profile on start menu.Any experience prefered.Thanks.
Deangellopeter
How to change image msn 8 Mac ?
Msn 8 is a Live messenger, once you changed your profile picture in only affects the database of the msn 8 developer so that it will take effect in your profile picture. It has nothing to do with your mac operating system profile in the start menu. It will not be changed.
I hope this suggestion will help you a lot.
Hello Deangellopeter,
As far as I know, to solve this problem you just have to personalize your user account. Go the control panel on your PC and change your picture, and then click disable to change your profile picture, then click OK. Then you will never have problems with your Mac.Â
Best of luck.
You want to change your profile image on MSN so it will change only from MSN it will not effect on another application and if you want to change the image  from the operating system so go to appearance configuration and change image there it will effect on your operating system.
Thanks
Raun Nelson
