How change the interface of a software
I like to give a different interface  to my HSDPA modem's mobile partner software.So as i know i tried to change many dll files and other files too with modified ResHack. I could change it a little bit. But i want to change the whole interface.So my question is how can i change whole interface on mobile partner software??
Best Answer by drolling
Answered By 0 points N/A #119938
Sometimes changing the interface of the application with ResHack or ResEdit would change the system work flow, or make the application not working anymore, but if the application is not UI based like win form you can change it easily like editing the sfx mode of winrar, winzip, or 7zip, but if the application is UI based on picture it hardly can change the shape and size, even other objects will not show on the resedit.
so I tell you, can change if the main form of the application is win form not the picture UI based.
Answered By 10 points N/A #119939
I don't think it is possible to change the whole user interface of the software. You might be able to change some of its components like dll. In addition to resources hacker you can also use hex editor it can also modify several settings. It could make your program completely useless. So be sure to create a backup before attempting any changes. I hope this helped.
Peter franklin
