jonny667
Posted on - 10/26/2011
I want to change the status of my IP address in iSeries from Inactive to Active after IPL performing?
I want to know about the procedures how doing this in DRP scheduled testing activity, In this activity I want to configure the DRP Io address to perform an IPL?
The production IP address is still Active while my DPR IP address in inactive.
How can I configure that please send me suggestions.
How to change IP status?
You can always change the status of your IP address. It is very simple and easy. You just have to download IP Changer. It is a great and very helpful tool that can display the IP status of your system and it will let you change and create different sets of IP. If you already downloaded the IP changer (search on Google), just click and go to IP sets and then click new IP Configuration. You can now make two IP sets and you can change any of them easily.
I hope it helps.
Thanks and have a great day!
Greg
