How to change the language from English to Turkish in Nokia N8?
I have decided to buy Nokia n8 new phone. Please tell me is there any option to change the language to Turkish? And please tell me, after I change the language will all functions work normally? Thanks
Answered By 5 points N/A #161562
Heres how:
1. Open your Nokia N8.
2. Press "Menu Key". Its the button at the lower left.
3. Go to "Settings".
4. Select "Phone Language".
5. Browse down the language that you want. Your choice is Turkish.
6. It will ask you to restart the phone with this language, choose "Yes".
Note: If the your phone language is not present, which is Turkish, then you need to get a language pack that includes Turkish. It can only be done  by a Nokia Care Point. You can find the nearest Nokia Care Point at:
www.nokia.com
Select your country, go to the support section, then select repair. After installing the language pack, do not update or else the phone will be reverted to its original firmware that doesn't include the Turkish language.
And yes the functions will work normally after changing phone language.
Hope this helps.
