I know it's a simple question for one who knows it. But I'm in problem with it. I've got a Nokia n8 hand set. I need to change its language in turkish language. How to change language in turkish in Nokia n8? Please, tell me elaborately.
Thanks
To change your language on your N8 to Turkish language first check it the language is available or not on your mobile site. Follow these steps it will lead you to change the language which you desired and also check the language there.
1. Press the menu button on your mobile.
2. Go to the tools and then setting.
3. In settings go to the general and then personalization. Here you will see language now scroll down and find Turkish language and select it.
