How to Change Logon Background in Windows XP?
Asked By 7060 points N/A Posted on -
Hi Experts!
I want to change the log on background in Windows XP. Is it possible? I want to change it with my own image. How can I do it? Need help.
Thank you.
Best Answer by lee hung
Answered By 75 points N/A #81275
Hi Mdarifsadik,
To change your logon background in XP, just click start, in the task bar then run. In the open blank field type, REGEDIT and then press enter on your keyboard.
You are now in the registry editor. Here, navigate to the following:
HKEY_USERSDEFAULTControl PanelDesktop.
You will see a string named "wallpaper", double click on it.
Thereafter enter the full path and name of the image/picture you want to use as the background, which should probably be in the .bmp format.
Click ok, and then close the registry editor.
Restart your computer for the changes to take effect.
Hope this helps.
____
Lee Hung
Answered By 0 points N/A #81276
If you want to put an image or your favorite picture in your personal computer, you have to click the start button and go the control panel; click personalization; You will see the visuals and sounds on your computer, just click the Desktop Background and browse your picture or for the image and set it as your background and click the save changes option.
If you want to put a screen saver, click the screen saver option; go to the settings. You may choose anything you want, for your computer and if you want to put Windows color, just click the windows color. You may customize the current color to change Windows borders, Start menu and Taskbar.
