How to change mb size of music?
I have 2gb music files in mp3 format and I want the size amount to be lesser so it will fit my 512mb card. Is there any way on how I can change mb size of music?
This can be done with music file compression, which can save disk space and allow you to add more files to your 512 MB card. If you have high bitrate music files, I suggest that you compress them first before putting them on your card. You can download the software for this at: https://www.addictivetips.com/windows-tips/quickly-compress-mp3-music-files-for-free/ .
You can read the step by step procedure after installing this file.
Nelson
You can use the JetAudio Media Player. It is actually a music player that can play well-known music formats but it has added features such as recording of sound, converting music files, rip CDs and burn it to a CD.
Just download and install it. Click Convert and select the MP3 files. In the output area, select MP3 and 64 bits per second or 48 bits per second. This is your output sound quality. It will reduce the GBs into MBs.
