How to change nokia software?
Hi larry!
I will tell you that how can we change the Nokia software. The following steps will help you a lot.
1. For this purpose make sure that u have not inserted your sim card in the mobile.
2. Now connect the mobile via cable to dejan box
3. After connecting to dejan box you must run dls 2.7 and get all the information
4. Once you get all the information now you can upgrade or downgrade your phone.
5. Choose, which version of software you want for yourself.
6. After you choose the version of software, turn off mobile and remove battery .
7. Now again connect the mobile to the cable and press Enter from the Keyboard
8. press the mobile Power button Shortly
9. Now you have to wait, after it finishes, press the power button of the mobile longly.
10. You are done! now disconnect the mobile from the cable
At first you open your menu, then tools, File manager.
1. Select remove the software.
2. Install this software.
3. You Can change Nokia software one by one.
I think you try to do. Then Reply me.
Solution
Notifications
