How to change operator boot logo galaxy s3? Galaxy s3 is a mobile phone with a sensitive setup or menu settings. I need some help to figure out those settings that will possibly change the default one. I hope you can find some way to let me know the changing operator boot logo process on galaxy s3 mobile phone.
Lindsay Wendy.
In order to have your own desired logo instead of operator logo you have to follow one of these techniques.
· Get your Samsung galaxy s3 rooted. But it’s a dangerous method it can brick your android. For help regarding this visit http://galaxys3root.com/
· Best way to change the logo is to change the default logo image with your desired image. The new image should be in .rle format to get it work. Once you have the image in .rle format then using the root explorer replace it with default logo image (init named) under root folder.
Root Samsung Galaxy S3
Step to root your device:
1) Make sure you have access to a Windows based computer, to your smartphone and to its official USB cable.
2) On the computer and on your handset deactivate the security
3) Then “menu -> settings -> developer options”; from these check the USB debugging option
4) Odin must be used.To download odin (http://www.android.gs)
5) Install the galaxy S3 drivers.
6) Run Odin on your computer
7) Enter your S3 in download mode
8) Select the option dubbed as “pda” from odin
9) Pick the root package from your computer.
