Is there a way that I can change the language interface of Photoshop for Mac into another language? Right now, I am using an English version and I want it to change into French language. Please send me a guide on how to do it properly.
How to change Photoshop Mac english interface to French?
Hi Rochelle,
Open edit menu in Photoshop then click on preferences then interface in UI text options you will find UI language try to open it and change it if there isn’t French you will have to purchase French Adobe Photoshop because your language is tied to your serial number.
Hello Rochelle T Tritt,
          As Photoshop is available in many languages. And you can also change your languages to any of the international language. All you need is to go to the edit menu from there you need to go to the preference menu. After that you need to go to the Interface and after that interface language and from there you can change your interface language to any of the available languages.
