How to add proxy to access ban websites?
Asked By 120 points N/A Posted on -
Hi I am living in my college hostel and using internet with a broadband service. Here https://www.facebook.com/ has been banned. Now I want to browse Facebook. I know I can do it with proxy. But I don't know how to change proxy? Please Help me if you can……
Best Answer by Hinam Slop
Answered By 0 points N/A #89424
If you use firefox you can do it by using firefox "foxy proxy" add-ons. Search for this plugin and instle it. Then active it. After that you can start browsing  FaceBook in you pc.
Answered By 0 points N/A #89425
Go to this site. Find a working proxy.
Then put it to your Firefox network setting manual proxy setting.
Put port number into port box.
Then check your IP by going here.
After that go and use FaceBook where you are banned.
Answered By 120 points N/A #89426
Thanks to Jonathon Trot, but when I active foxy proxy then my internet connection stops working. What to do?
Answered By 0 points N/A #89427
I think you failed to set proxy into foxy proxy. Ok you can now follow the instruction of  Hinam Slop. It is easy to follow.
Answered By 120 points N/A #89428
Thanks to Jonathon Trot & Hinam Slop for helping me to find out solution. Ok.
