I and my friend both use a Verizon 4s 16gb . He didn't face this problem but I do. I had deleted all my texts from my phones to start a fresh new phone but contact names are not showing.So, I need to solve the problem and change text message from name on iPhone.
How to change text message from name on iPhone?
Thank you for choosing Techyv.com to provide you with expert solutions to your IT related problems.
There are several steps you can take to sort out your current problem:
Go to Settings > General> International Assist> Language and change it from English to British English and back again.
Dial *228> select option 9 and then changed the language to British English and then go back to English.
Call *228> select option 1. Closed all the running applications. Also try to turn off Exchange and iCloud and turn off your SIM off because each may be contributing to the problem.
Hi,here’s the solution for your question.
The default display for text messages on your iPhone makes it possible for anyone who picks up your device to read part of the message you received, making it difficult to keep business-related messages private.
Alternatively, you can set up your phone so that when notifications for new messages are displayed, they don't take up as much screen space, or a notification doesn't display at all. You can change how your iPhone displays text messages in the Notifications part of your phone's Settings app.
