Hi everyone
I am using iPod and I want to change some tools and panels installed by apple like iPod front panel assembly. After a long effort I could not separate front panel with LCD because looked covered with glue please give me helpful suggestion how to separate the front panel with LCD.
Thanks in advance
How to change tools and panels installed on the ipod
Hello Jina Sharman,
The iPod front panel can not be separated from the LCD as this comes in one single part. If you have a new front panel ( that is Glass Panel, LCD and digitizer) then there is a way to replace it. I am suggesting you a website, please visit it, it provides you with a step by step guide with pictures to replace your iPod's front panel.
Link:Â http://www.ifixit.com/Guide/Installing+iPod+Touch+4th+Generation+Front+Panel+Replacement/3639/1
Make sure you have the following items before you continue:
– Heat Gun
– Screw Driver
– Tweezer
– Ipod Opening tools
