I am using Windows XP because it is very stable. It doesn't easily crash and my system performance is faster. Please suggest the best free software so I can change some desktop items like cursor PNG windows 7 iconin my computer.
How to change XP cursors to Multi-resolution Windows 7 cursors
Here are the steps if you want Windows 7 cursors for Windows XP
1. Download Aero Cursors for XP.Â
2. Extract the zip file you just downloaded.
3. Go to Control Panel > Mouse > Pointers.
4. Change the icon as you have desired.
5. Save and enjoy your new cursors!
Hope this helps.
Korber Owen
Hello Austin,
Have a nice day
It's pleasure to solve your problem.So you want to use Windows 7 cursor, so here i am going to give you best tool which can convert cursor to the desired Windows 7 cursor.You can easily use this for conversion of cursor.
http://cursorfx.softpedia.com/
Hope this will work.
Cheers
