How to change your browser to Google chrome?
I Can't change my browser to Google Chrome. Please help me. Thank you!
I want to change by default to Google Chrome
Greetings! There are different ways of setting Google Chrome as your default browser. It can be done with the Control Panel or you may try the easier way where you access Chrome's settings.
First, open Google Chrome and in the address bar, type chrome://settings/. A new tab will open and scroll down and look for 'Default Browser'. There it will display if Google Chrome has been set as default. If not, click the button to set it as default.
There you have it! If Google Chrome is still not your default browser after doing the procedure, your PC may be affected by a virus. Try scanning with your antivirus to see if there are any malicious files in your computer.
