How to changing to windows classic style 2007?
I have MS Office 2007 installed and was hoping if it is possible to changing to windows classic style 2007? If it is possible then tell me how it is done?
Any kind of help would be appreciated.
Hello Toby,
I know how frustrating it can be getting used to a new interface when you are so used to using the older model.
There is a program that you can download that will help you with your problem.
It will change all the newly added buttons such as "ribbon" back to the older interface and buttons that you might be familiar with.
The program is on download.cnet.com and can be download completely free.
I will provide a link to the download page.
I hope this solution help solve your problem,
Have a great day.
Toby,
When upgrading a program sometimes it is difficult to change to the new concepts and new processes. There is a way to change things to the "Classic Style". I will provide you with a couple links that can help you achieve this process: http://www.fileguru.com/apps/microsoft_office_2007_to_2003_converter and http://www.brothersoft.com/classic-style-menus-and-toolbars-for-microsoft-office-2007-306249.html. This should help you in your endeavors.
