Liam Sam
10 points
Posted on - 12/09/2012
 I have developed a web site and I want to find a domain name with the file extension .com. Is there any method to check domain availability on all leading domain name registrars same time without going one by one with the file extension .com. Please give me a good solution.  Â
How to check domain availability on many registrars same time?
As a matter of fact the search at the single time on thousand domains is not accurate anymore because of the domain registrars. The Whois database keep by their own domain registrar. For accurate results of the domain you have to look the domain in the domain registry which is shared. Locate the name reserved by which registrar. For correct information on the registrar database make visiting and query. Here is the URL to checkout which will help you.
http://www.betterwhois.com/
