How to check if windows 7 is genuine
So you have a CPU with Windows 7 installed, but you’re not definite if you are organizing  a genuine account of the OS. You may have this concern if you taken a copy of Windows 7 or if someone installed it for you. Anyway, nearby are a couple of dissimilar ways to check and make sure that your Windows 7 reproduction is genuine
Answered By 0 points N/A #186672
To determine if you have a legal copy of Windows 7 is to use the authentication device on the Microsoft website. If you ever tried to download informs from Microsoft, you’ve probably noticed that from time to time your copy of Windows has to be authenticated before it allows you to start the talk. Well, you can use that tool independently of upload an update by profitable to the subsequent .Tick on the Authenticate link at the upper. Brand sure that you visit the site despite the fact in Internet Explorer, otherwise it will ask you do download a minor program onto your computer in order to authenticate.
Answered By 0 points N/A #186674
A genuine copy of windows is one that has been licensed, published and distributed by Microsoft or a trusted partner. A genuine windows you are eligible to receive updates from Microsoft every time there is an update available. The best way to identify if you are running a genuine copy is to validate your copy on their website. Click here for a direct link to that page.
Answered By 0 points N/A #186676
To check if the installed Windows 7 is genuine, you should select Start, and right click on the Computer, select properties. At the bottom of the page, activation status will be displayed. If the Windows is activated, it means the Windows 7 is genuine. If it is not activated, you could try to activate it via internet or by phone.
Answered By 0 points N/A #186677
Hi
To check your Windows 7 is genuine first of all click Start and type Activate Windows on the search field. If you see the box that says "Activation was successful", your Windows 7 is activated and genuine. Also pay a visit this Techyv link to know More helpful information. How to recognize genuine Windows 7
