How to check imsi nokia on my laptop?
Hi Experts,
I am having imsi nokia software on my laptop.I want to check imsi nokia status on my laptop.I tried it on about imsi nokia on that software.But there it is not indicated whether it is updated or not.Can anyone tell me to check this.Thanks.
Desireenataliaa
Answered By 15 points N/A #131457
Try to check the settings and options of your imsi nokia software in your laptop. Or right click the software go to properties, open file location you can see all the folders located. Check if you can see an update folder. There are softwares that needs to be updated and there are also that don't. Just visit the website of the software and check for latest versions.
I hope this will help you.
