How To Check Internet Speed: Different Methods.
I have a problem in downloading and uploading photos, videos, and files. Opening a web page also takes a longer time. Do I want to know how to check internet speed?
Method 1: By using a PC when it has an internet connection.
Step 1: Click on Network after clicking on Start menu.
Step 2: Choose the option of View Status for getting the information of the speed of the internet.
Method 2: Using a Mac.
Step 1: Type command "Command" + "F" in Activity Monitor.
Step 2: Double click on the application.
Step 3: Click on the Network tab.
Method 3: From the internet.
Step 1: Close all the applications.
Step 2: Search internet speed tests online.
Step 3: Choose a server that is closest to your location.
Step 4: Compare your internet speed.
