Efficient way on choosing the best Anti-Spyware Software
I am looking for a good anti-spyware software for my computer as i have been very badly affected by viruses where I had to regularly format my computer.
Hi!
Nevertheless, viruses and spy worm software are sometimes very deadly than anything else on the internet. The only solution to cope with them is to have a good Antivirus and Anti spyware software installed on our computer. Following is the list of some useful software in this regard.
AVG Antivirus free Avast Antivirus free Microsoft security Comodo Antivirus Avira Antivirus
Hope these software helps you in protecting your computer from being affected.
Another thing which is very crucial to be mentioned is that be careful while downloading any file from the internet or while responding to an unknown email. Especially emails offering exciting benefits from an unknown resource is undoubtedly attached with some kind of disaster for your computer.
Hope it helps you.
There are many Anti spyware downloadable from the internet. You can even pay for a credible Anti spyware if you have to. But setting that aside, even with the most dependable and most expensive Anti spyware you can get, the bottom line is “YOU”, the user. You should also be careful in opening files you get from email.
If you suspect of something fishy on a piece of file you receive from an unsolicited sender, you should delete it and never to attempt to open it and even download it to your computer. This may harm your precious computer and worst, it can damage your files as well.
If you think your computer is already infected with a virus, what you need to install is a virus removal tool because if you try to install an antivirus, it may not install because of the infection. The malware may usually block the installation process. A virus removal tool has its own special method that prevents the installation from getting blocked.
Download Sophos Virus Removal Tool and install it. Once installed, start Sophos then wait for the virus signature database to get updated. When updating is complete, click to start scanning the computer. When a virus is found at the end of the scan, remove it then repeat the scan over and over until it no longer detects a virus.
The tool scans everything on your computer including devices connected via USB port. When it is finished, you may now try installing your preferred antivirus program:
