How To Choose Laptops For Computer Engineering Students.
Asked By 15 points N/A Posted on -
With so many laptops in the marker it is confusing to go with which one. To decide we need to have a greater understanding of the device. Suggest and brief about the laptops for computer engineering students.
Answered By 0 points N/A #116306
THINGS TO BE KEPT IN MIND:
1) Engineering includes computer software like AutoCAD, Catia etc. so an engineering student must buy a laptop with CAD GPU designed for modeling and simulation. The recommended ones are FirePro from AMD. They are specifically made for fast calculation. Though the gaming GPU does the same work but with a slower speed. CAD graphic card focuses on perfection, and high level of reliability. It contains different algorithms for each task. Updated on September 29, 2016
REQUIREMENTS FOR AN ENGINEERING LAPTOP
1) 8 GB RAM.
2) SSD.
3) Screen resolution of at least 1600*900 pixels.
4) I5 Core processor.
5) Graphics card.
6) Processor must have speed.
7) Good connectivity.
8) Screen size should be moderate.
9) Video cards.
10) Operating system.
Some of the recommended laptops are as follows:
1) Lenovo Y50 Touch
  • 2 GB graphics card.
  • Hybrid SSD drives.
  • Touchscreen.
  • Storage capacity of 1 TB.
  • Screen resolution of 1920*1080 pixels.
  • Screen size is 15.6 inch.
2) Toshiba Satellite S55
  • Customizable touch screen.
  • Good battery life.
  • I7 Core processor.
3) HP Envy 15t
  • Touchscreen.
  • Windows 10 operating system.
  • 16 GB RAM. 4) DELL XP S15
  • Windows 8.1 operating system.
  • 512 GB OF SSD.
  • Screen resolution of 3200*1800 pixels.
