How to choose right apps for my android phone LG Lucid 4g?
How to choose the right applications for my phone LG Lucid 4G when it comes to proper loading and executing the apps that avoids force closed and unsupported software application?
The LG Lucid 4g is designed to have an easy to use and easy to learn experience for smart phone users. To choose the best applications, first you would have to consult the manual to find out the best application for your phone. You could also visit their website to find out. Ensuring that there is software updates will be an appropriate thing and can correct some of the issues that may cause some distress on your phone. You could also search for applications from Google Play. It could be of help in finding some of the best apps for your phone.
The LG Lucid 4G or LG Lucid 4G VS840 Smartphone is not a GSM device and will not work on any GSM network in any country. It is a 4G LTE device operating on 2G, 3G, and 4G network bands using CDMA, EVDO, and LTE technologies. This model was announced on March 2012 and released on April 2012.
It measures 119.1 x 62.2 x 11.4 millimeters and weighs 142 grams. It uses a micro-SIM card. It has an IPS LCD capacitive touchscreen display with 256K colors at 480 x 800 pixels screen resolution. It is protected by Corning Gorilla Glass. It runs on Android 2.3.6 Gingerbread upgradable to Android 4.0.4 Ice Cream Sandwich.
It is powered by Qualcomm Snapdragon S3 chipset, Dual Core 1.2 GHz Scorpion processor, and Adreno 220 GPU. It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus. The camera supports face and smile detection, and geo-tagging. It can record video in 1080p at 30 fps.
It has a secondary camera that supports VGA. It has Wi-Fi 802.11 b/g/n with Wi-Fi Direct, hotspot, and DLNA; Bluetooth 3.0 with A2DP and EDR; GPS with A-GPS; and microUSB 2.0. It supports accelerometer and proximity sensors. The pre-installed web browser supports HTML with Adobe Flash. It supports Java.
It runs on a removable Li-Ion 1700 mAh battery with standby time up to 350 hours and talk time up to 8 hours. It is available in Black color only. Regarding the application you want to install on your phone, you should install apps that support Android 2.3.6 Gingerbread and later. To install apps, go to the Google Play Store on your phone.
Your phone needs to be connected to the internet to use the Google Play Store app.
Notifications
