How to clean install Windows vista- With the help of steps.
I was trying to download a file and then I came to know that I was a virus. I think my computer is corrupt now after downloading of that file. How to clean Windows vista?
If you download a virus them your system may get corrupt for coming out of this situation, you need to clean Windows vista.
Step 1: Restart your system after inserting Windows Vista disc.
Step 2: Choose your language.
Step 3: Choose the drive where you want to install Vista after selecting Custom.
Step 4: Select Format and then Yes.
Step 5: Get agree with the terms and conditions of installing Vista.
Step 6: Set your location, Windows update settings, username and other details.
Notifications
