How to clean my laptop to make it faster by different methods?
Most of the time, I need my laptop to work for creating presentations and documents. With each passing day it is becoming slower. How to clean my laptop to make it faster?
Laptop may get slower due to the lot of applications or due to the several programs running together. Freeing some space can also help in increasing the speed of laptop.
Method 1-
Step 1: Disable programs and applications that are not under use.
Step 2: Close the unnecessary tabs.
Step 3: Restart your laptop as it may increase the laptop speed.
Step 4: Delete or remove the unnecessary files, documents, folders and other media.
Method 2- Mac.
Step 1: Click App store.
Step 2: Select System Preferences after selecting Apple menu.
Step 3: Choose Login Items and then Users and Groups.
Step 4: Click on the program that you don't want to open.
Step 5: Select Applications followed by Utilites.
Step 6: Select Activity Monitor and then Memory tab and then Memory filter.
Step 7: Choose Quit after double clicking on the program.
Step 8: Click on Dock after clicking Minimize windows using.
Step 9: Change “Genie effect” to “Scale effect”.
Step 10: Choose System Preferences and then Accessibility.
Step 11: Allow Reduce transparency.
